Activity Forums Maxon Cinema 4D after render-transparency problem.
  • Adam Trachtenberg
    September 7, 2008 at 4:23 am
    Looks like you may need to increase your “ray trans” limit in render settings. That determines how many layers of transparency the raytracer calculates. If you exceed the limit you get black.
  • Yasu Kominato
    September 7, 2008 at 4:59 am
    Thank you!
    I went to render settings>option>ray depth-after I increased few numbers, shadow disappear. Is that where I should modify, right?
  • Brian Jones
    September 7, 2008 at 3:37 pm
    yes, that’s right
