Activity › Forums › Apple Final Cut Pro › After importing a video into an event a “Modified File” error is displayed.
  • After importing a video into an event a “Modified File” error is displayed.
    Posted by Emaduddeen Leiman on February 18, 2024 at 8:34 pm
    Greetings everyone.
    I just imported a video file in my Final Cut Pro Project and I’m getting an error that reads “Modified File” as shown in the screen shot. What is this and how can I import the video into the project without the error? All help will be appreciated.
    Thanks.
    John Wimberly replied 1 year, 3 months ago 4 Members · 6 Replies
  • John Fishback
    February 18, 2024 at 8:52 pm
    Checkout this link. Hope it helps.
  • Emaduddeen Leiman
    February 18, 2024 at 9:05 pm
    Hi John,
    I tried the first answer listed in the link you sent but couldn’t locate the “Delete Generated Event Files” menu item under “Files” but did find “Delete Generated Clip Files” and when I clicked that menu item I got a scary warning the files inside and outside the library will be deleted so I canceled it. Is it saying that my original file will also be deleted? If it will not touch my original video file then I will try it.
  • John Fishback
    February 18, 2024 at 9:24 pm
    Before going to the File menu, make sure your Library is selected in the Browser. Then you should see the Delete Generated Files options.
  • Emaduddeen Leiman
    February 18, 2024 at 9:30 pm
    That was it. No more error! 🤣
  • Brie Clayton
    February 18, 2024 at 10:29 pm
    Thanks for solving this, John!
  • John Wimberly
    May 22, 2025 at 10:34 pm
    Deleting the generated library files worked for me as well.
    Thanks to everyone for this helpful thread!
