Activity Forums DaVinci Resolve After GTX 470 install, Mac Pro fans can dry my hair!
  • After GTX 470 install, Mac Pro fans can dry my hair!
    Posted by Lee Eaton on January 16, 2012 at 6:44 am
    First, a big thanks to all the vets on this forum for both their technical and artistic advice.
    Recently installed a Mac flashed GTX 470 from the macvidcards gentleman on ebay. Nice chap.
    On a fresh Snow Leopard 10.6.8 install:
    After machine boots up, without using any programs, my fans speed up quite a bit, even
    when I’m not using any programs. My machine sounds like a hair dryer. I installed current quadro 4000 drivers, updated CUDA, uninstalled the AGP.kext from system/library/extensions.
    Fresh Lion 10.7.2:
    System boots fine. I only get the hair dryer when using Resolve for a little while. Arri Alexa and Apple Pro res HQ files. Couple of nodes, no blurs. Latest CUDA (Lion has quadro drivers) and uninstalled AGP.kext
    Both graphic cards are double slot and right on top of each other like two sweaty prisoners about to be in love. Maybe that’s whats going on? They don’t feel all that hot to the touch though. The cards that is.
    I’m aware that this is not an approved Resolve setup but a few other folks have reported their success with the GTX 470 so I thought I’d check it out. The power wattage seems to be in line. Any suggestions? Am I underpowered? ATI, Nvidia conflict? Anyone else run into this?
    2008 MacPro 3.1
    (Lion 10.7.2 & Snow Leopard 10.6.8)
    2.8 quad Xeon
    14 GB Ram
    ATI Radeon HD 5770 slot 1 GUI (Power jumped from DVD drive)
    Nvidia GeForce GTX 470 slot 2 GPU (no monitor attached)
    4 Hard drives
    Avid Artist Color
    Apple 27″LED Display
    Blackmagic Decklink HD DL
    Lee Eaton replied 14 years, 7 months ago 3 Members · 3 Replies
  • Dan Marlow
    January 16, 2012 at 10:58 am
    Hi. Probably need to reset your P RAM. Power down, unplug all peripherals. Leave for a couple of minutes then plug all back in and power up again. That should fix it.
  • Paul Jay
    January 16, 2012 at 11:17 am
    A P RAMM zap is Command/Option PR on startup.
  • Lee Eaton
    January 16, 2012 at 4:19 pm
    The PRAM zap did not solve the Snow Leopard issue. The loud fan is the HD/Expansion fan, it’s at 1800 – 1900 RPMS
    other fan speeds are:
    Power Supply: 600
    CPU: 500
    Exhaust: 1050
    This is with no programs running.
    Got this from the Macvidcards guy:
    “First step is to figure out which fan is making the noise.
    Download
    iStat and it will allow you to rad speeds of the System Fans.
    It may
    show you the 5770 fan , I don’t know. I doubt that it will show you 470
    fan.
    You can run the Mac Pro with the side off and if the loud fan
    wasn’t a system fan, it will be one of the GPUs.
    Fortunately, you can
    simply stop them with your finger for a second to see which one is making
    the noise.
    Unfortunately, the 5770 is a Dual slot card and requires more
    power. Also, having it side by side with 470 is likely obscuring the input
    side of 5770 fan, or pulling air the wrong way through 470.
    You may want
    to consider getting an Apple OEM GT120. It could run the 27″ Apple display
    and it does not need any external power. It’s shorter length and single
    slot size would free up a lot of space and airflow in the Mac Pro and it
    and 470 would not be interfering in each others airflow.”
