Activity Forums Compression Techniques After encoding, first frame has turned green
  • After encoding, first frame has turned green
    Posted by David Schneider on March 19, 2008 at 4:14 pm
    I used Compressor with this method at Ken Stone’s site to encode a video for YouTube: https://www.kenstone.net/fcp_homepage/youtube_compressor_gary.html
    For some reason, in the resulting quicktime, the first frame, where it’s supposed to be solid black, is a sickly green. I’ve double checked that I was following all the settings in the tutorial, and I’ve I’ve examined my original video… the first few frames are definitely supposed to be solid black (it’s 2 seconds of black slug directly from FCP).
    Any ideas on what might be causing this, and how to get rid of it?
    Daniel Low replied 18 years, 6 months ago 2 Members · 1 Reply
  • Daniel Low
    March 20, 2008 at 9:56 am
    Do you get the same result when encoding to a different CODEC?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
