Activity Forums Adobe After Effects After Effects/Illustrator problems
  • After Effects/Illustrator problems
    Posted by Richard Lutz on January 22, 2012 at 8:34 pm
    Hi guys. I’m having a little difficulty with an illustrator file in After Effects. I recently did some work on on a Illustrator file then brought it into After Effects as a composition. I didn’t merge the layers. (There was like 75 layers.) Later I tried to open the project later but didn’t see any of the graphic elements that I was previously working with. All I saw was the solid that I created for my background. Am I doing something wrong? Why would I be having trouble seeing the Illustrator graphics in After Effects?
    Erik Waluska replied 14 years, 8 months ago 2 Members · 3 Replies
  • Erik Waluska
    January 22, 2012 at 9:07 pm
    Is the illustrator file with the folder and comp you imported still present in the project window? Are the illustrator layers you were working with still present in the timeline but you just don’t see them in the composition window? If so, check that your view option is set to active camera and not top or side.
  • Richard Lutz
    January 23, 2012 at 5:08 am
    Yeah. I can see all of the files on my timeline, however I can’t see anything in my viewer or when I select an individual layer.
  • Erik Waluska
    January 23, 2012 at 3:49 pm
    I assume that you’ve checked that the Composition window view is set to Active Camera. Obviously, check that the visibility (eyeball switch) for all of the layers is on, the layers are above the solid in the layer stack in the timeline, and the opacity is not at zero. If you still haven’t figured it out then could you post a screen shot of your entire AE window?
