Activity › Forums › Adobe After Effects › After Effects Zig Zag Animation
  • Nils Hammers
    May 15, 2024 at 11:10 am
    Seems, you have deleted the reference vid.. Is your question still unanswered?
  • Sasha Sinni
    May 15, 2024 at 11:13 am
    Hi Nils,
    Thank you for letting me know, I just uploaded it back to my folder, you may take a look now:)
  • Nils Hammers
    May 15, 2024 at 4:26 pm
    Assuming you have there a bunch of small square layers, I would animate it with sine expression for y coordinate, and some more automation. Anyways, this topic must be well covered by others, you can find several ways to tackle the thing, e.g. https://youtu.be/DY73Kyk0T7A?si=PYUpT7q2_yJ7ZEAV&t=147
    See, if you can figure out yourself, otherwise give a shout.
    Best of luck!
  • Sasha Sinni
    May 15, 2024 at 5:17 pm
    Thank you so much for taking the time to answer, I ended up using this tutorial to solve my issue and adjusted the key frames to fit my look.
    Cheers,
  • Brie Clayton
    May 15, 2024 at 10:24 pm
    Thanks for helping to solve this, Nils!
