Activity Forums Adobe After Effects After Effects: XML values to sourceText
  • After Effects: XML values to sourceText
    Posted by Allard Rothengatter on October 6, 2014 at 9:38 am
    Hey Guys,
    This has probably been discussed somewhere, but I am having a hard time finding a suitable solution.
    I am looking for a way to get XML values into a text layer’s sourceText so that I can easily update several text layers in an animation by just changing the XML and then run a commandline renderer.
    Any of you guys have some info on how to do this??
    Thanks in advance…
    Cheers,
    Allard
    Walter Soyka replied 11 years, 11 months ago 2 Members · 1 Reply
  • Walter Soyka
    October 6, 2014 at 11:24 pm
    There are a few good tools for doing this sort of work, including CompsFromSpreadsheet [link] and pt_OpenSesame Server [link].
    If you can wrap your programmatic output in JavaScript instead of XML, you can read it from an expression with $.evalFile.
    You might be able to save your After Effects project file as After Effects XML and process that programmatically for text replacement.
    You could also write a script to handle the I/O, parsing, and text replacement.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
