Activity Forums Media 100 After Effects .xml files import
  • After Effects .xml files import
    Posted by Mark Legrand on June 14, 2008 at 11:29 pm
    Hey guys,
    I am using M100 producer 12.6 & after effects CS3. I am having difficulty bringing the project timeline into AE. I exported the timeline and got a .XML file, but AE will not recognize the file as legit file. I downloaded the AE importer from the Media 100 website, but I am not sure what to do with the AE_XML_Project_Importer.bundle I downloaded. There is one file already in the Media 100 folder with the same name.
    So where do I go from here. Do I put the AE_XML_Project_Importer.bundle in a AE folder?
    Any help will be great.
    Mark LeGrand
    Pro One Video
    Travis Paulding replied 18 years, 1 month ago 3 Members · 5 Replies
  • Chris Clephane
    June 16, 2008 at 3:34 am
    You need to put the AE importer plugin into the MacintoshHd/Applications/Adobe After Effects CS3/Plugins/Format folder.
    Restart AE and create a new Project.
    You should be able to OPEN the M100 generated XML file at that point. The AE import dialog (once you single-click on the XML file) will show (Media100 Composition) as the filetype.
    “Open” and AE creates a folder with all the media elements and a compsition with your edit/timeline in it.
    I edit video. I post sometimes.
    I fix things. I eat marshmallows.
    I play drums. I drink scotch.
    I like TV.
    Done typing now.
  • Mark Legrand
    June 16, 2008 at 8:15 am
    I tried the suggested steps, but without success. What should be the name of this file, and where can I get it. I only have the trial software that I download and converted to a valid copy. No disc. I downloaded the AE file from the website, but this hasn’t worked. I have used Media 100 since 2.4 and I am used to the.m1a files and using them with AE.
    This is what I tried
    I placed the below in the folder
    Media 100 XML Project Importer
    (this was already in there) MediaIO Folder > MediaIO2.plugin
    MediaIO2.plugin ( I tried to move this from the MediaIO Folder directly in the Plug in Folder AE3 crashed.)
    Thanks Mark LeGrand
    Pro One Video
    Mark LeGrand
    Pro One Video
  • Chris Clephane
    June 16, 2008 at 8:15 pm
    1) As per my directions….this the only thing you should have placed in the plugins/format folder
    ——> AE_XML_Project_Importer.bundle
    2) This is for AE 6.5 only !!REMOVE IT from your CS3 folder!!
    —–> Media 100 XML Project Importer
    3) Don’t mess with this.
    —–>(this was already in there) MediaIO Folder > MediaIO2.plugin
    4) This has nothing to do with Media100 AE imports don’t mess with it.
    —–>MediaIO2.plugin ( I tried to move this from the MediaIO Folder directly in the Plug in Folder AE3 crashed.)
    You should have only dragged one file.
    EXAMPLE:
    https://www.digitalsupercast.com/cow/path.jpg
    Once installed correctly, you can confirm correct installation by creating a new project, and then under the IMPORT dialog (I believe I said OPEN earlier) selecting one of your XML files. Single click on the XML file and you shoudl see the following response from AECS3.
    https://www.digitalsupercast.com/cow/import_dialog.jpg
    Any other result means you added something extra, inadvertently removed something or accidentally put something in the wrong spot.
    Good luck.
    -C
    I like TV.
    Done typing now.
  • Mark Legrand
    June 17, 2008 at 9:59 pm
    Thanks for your help Chris.
    I have placed all the plug-ins as prescribed in your post, thanks for the images.
    I am able open the xml files in After Effects, but I have new issues. Once the xml is in the project window and than I open the comp, I get this message: I tried three different separate projects to confirm my results.
    After Effects error: Error (4) reading frame from
    file “/Volumes/Weddings 300/080105 Avril Project
    Media/Avril pre-NT2-V300”.
    ( 86 :: 2 )
    I am unable to view the comp at full resolution. If I toggle to half resolution than everything previews in the comp. I further tested this by try to make movie at full resolution and received the same error message.
    I create a XML file on one of the longer timelines. When trying to import this file I received this message.
    After effects: AEGP Plugin Media XML
    Program Importer: Assertion failed: lastEffectInfo
    = = _null at (module info not available) [0x0]
    ( 5027 :: 12 )
    Any ideas?
    Mark LeGrand
    Pro One Video
    Mark LeGrand
    Pro One Video
  • Travis Paulding
    July 29, 2008 at 5:46 pm
    Try renaming your source files. I couldn’t figure out the problem with this error message either so i started the general fix attempts. Seems to work fine for me.
    Travis Paulding
    Dir. of Technology
    St. Simons Community Church
    Quad 3.0 MacPro; 250 & 500 GB internal; 4 GB Ram:::
    15″ MacBook Pro, Dual Core 2.0, 2 GB Ram, 100 GB HD:::
