Activity Forums Adobe After Effects After Effects WON’T render out QuickTime video???????
  • After Effects WON’T render out QuickTime video???????
    Posted by Aaron Fletcher on October 13, 2011 at 8:57 pm
    Help.
    I am not able to render out any type of QuickTime move from After Effects. I’m still able to render out any other types of video from After Effects successfully, but when I try to choose QuickTime, and then select a codec, I have an option of “0” and “-1″…..
    When I first click on the Output Module, it says:
    “After Effects: One of the output modules could not be imported, It has been reset to use the default settings for the selected file format.”
    I’ve tried rendering both the 0 and -1… but get an error after 1 second that says:
    “After Effects error: Rendering error while writing to file /users/xxx/xxx/xxx/xxx/xxx/xxx.aep/xxx.mov An output module failed. The file may be damaged or corrupted. (-1610153464)
    The status says: Failed at 0;00;00;00
    I’ve tried making a very simple comp and still the same thing.
    I downloaded Quicktime 7.6.6 b/c sounds like a QT issue..
    Uninstalled All adobe products and reinstalled…
    Nothing..
    Any thoughts???
    Using:
    CS5.5 After Effects on Snow Leopard
    Mac Book Pro, Intel Core 2 Duo, 2.16 GHz, Number of Process: 1, Number of Cores: 2, ATI Radeon X1600)
    Aaron
    Aaron Fletcher replied 14 years, 10 months ago 2 Members · 2 Replies
  • Kevin Monahan
    October 13, 2011 at 9:13 pm
    Sounds like you’ve got a corrupt clip. See if the error message calls up the clip. If not, create a second comp and copy the first half of your piece into it. See if it will render. If it does, continue this process of “Halves” to isolate the clip. Once you’ve found it, replace it and see if you can render then.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Aaron Fletcher
    October 13, 2011 at 9:52 pm
    Hey Kevin, Thanks for the quick response.
    I’ve created a completely different COMP using only Solids(very simple) and it still gives me the same ERRORS.
    Aaron
