After Effects won’t import Premiere Pro Project
OK, i have cs5, and I like to edit videos in premiere before transferring them to after effects. this method was fine until i upgraded to cs5. then whenever I have a premiere pro project that is version cs5 that i want to import to after effects, the program starts wigging out and a thing pops up which says:
After effects: aegp plugin premiere pro import: Can’t load premiere pro project, this version is not supported. (5027 :: 12)
anyone have run into this problem before? anyone got a solution?
thank you very much, guys!
