Activity Forums Adobe After Effects After Effects with AMD 64 Bit Processor.
  • After Effects with AMD 64 Bit Processor.
    Posted by Bruce Orkofsky on June 11, 2005 at 4:26 am
    Hi, I have After Effects 6.5 Professional and have been trying to learn it as a beginning user. I am working through some tutorials in the book Creating Motion Graphics with After Effects Vol. 1 and when I go to render the project from the render queue I get an error message that After Effects has crashed. When I close that error message then I get a message that I have one chance to save my project, when I close that then After Effects closes down. I have and AMD 64 bit 3500+ processor. I installed everything on my other computer that has a 32 bit AMD 2800 processor and it renders fine. I was wondering if ANYONE has had a similar problem or knows first hand if there is a compatibility problem between AE and the AMD 64 bit processors.
    Thank you.
    Bruce
    Bruce Orkofsky replied 21 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • Raf
    June 11, 2005 at 4:36 pm
    Hi Bruce,
    I have been editing with AE6.5Pro for over a year on AMD FX-51 with no similar problem. Using XP Home SP1 with 2gb ram and Nvidia Quadro FX 1100 video.
    Good luck.
    raf
  • Bruce Orkofsky
    June 12, 2005 at 7:31 pm
    Hi raf,
    Thank you for your reply, I appreciate the info. What speed is your AMD FX-51 processor? I don’t know if that would make a difference compared to mine or not.
    I’m beginning to think that I may have a bug in my system as I get an Application Error message when I boot up talking about a memory location when I boot up and saying that the referenced memory could not be read. Then it says Click on OK to terminate the program or Cancel to debug. I usually just close it but this might be causing the problem. Have you ever run into a problem like this? Or if anyone else reading this post has come across something like this please let me know.
    Thank you,
    Bruce
  • Bruce Orkofsky
    June 12, 2005 at 8:12 pm
    I forgot to mention that I am using Windows XP Professional with SP1 with 1 Gb ram and the ATI Radion X800 Pro with 256 mb of ram.
  • Rob Davenport
    June 13, 2005 at 2:44 am
    My question to you Bruce is why are you using a 64 bit processor without any software to support it?
    Best,
    Rob
  • Barend Onneweer
    June 13, 2005 at 9:04 am
    The AMD 64-bit CPU’s can also run a 32-bit OS fine. There’s not much of a speed gain. Most people using 64-bit CPU’s are waiting for WinXP 64-bit and suitable drivers.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Bruce Orkofsky
    June 13, 2005 at 2:56 pm
    That’s what I figured as everything else seems to run fine. It’s just when I try to render a project with AE 6.5 that it crashes on this machine. The same program works fine on my 32 bit machine.
    Thanks for your reply.
  • Bruce Orkofsky
    June 13, 2005 at 2:59 pm
    Hi Rob,
    Which software are you talking about, Windows XP-64? All my other programs seem to work fine, AE 6.5 works fine also except that it crashes when I try to render a project.
    Bruce
