Activity Forums Adobe After Effects After Effects widescreen output to avi doesn’t work
  • After Effects widescreen output to avi doesn’t work
    Posted by Jim Bucciferro on February 2, 2007 at 1:59 pm
    I have a widescreen (720×480) comp that I want to output to AVI. All of the comp settings seem correct and the only imported footage is a psd.
    When I output to uncompressed avi and import into my editor it sees it as 4:3.
    How do I get AE to export the 16:9 avi correctly.
    Jim
    Erik Pontius replied 19 years, 7 months ago 5 Members · 6 Replies
  • Steve Roberts
    February 2, 2007 at 3:19 pm
    If your editor sees it as 4:3 squeezed, he/she needs to flag it as widescreen somehow in the editing app.
  • Jim Bucciferro
    February 2, 2007 at 3:59 pm
    By editor I mean my editing application (Avid Liquid 7). I can resize the avi by changing the x-value and it will resize. But Liquid sees it as 4:3.
    Are there any additional render or comp settings in AE to make this work correctly?
    Jim
  • Mylenium
    February 2, 2007 at 7:08 pm
    [jimbucc] “Are there any additional render or comp settings in AE to make this work correctly?”
    The problem is not AE, it’s your edit suite. Since the overall size in pixels is the same, you need to flip a switch somewhere in Liquid to make it interpret your footage as 16:9 instead of 4:3.
    Mylenium
    [Pour Myl
  • Jim Bucciferro
    February 2, 2007 at 7:25 pm
    I will set the import settings for Liquid and try it again.
    Jim
  • Iancorey
    February 3, 2007 at 4:37 am
    Look for the words “anamorphic” or “pixel-aspect”.
  • Erik Pontius
    February 3, 2007 at 6:26 pm
    In Avid Express, at least, Liquid might work similarly, you right-click in the Program monitor window and choose “16:9 video.” The source and program monitors then unsqueeze the video to widescreen.
    Erik
