Activity › Forums › Adobe After Effects › After Effects Warp Stabilizer
  • Todd Kopriva
    September 20, 2011 at 3:18 am
    Restart your computer and try again.
    If that doesn’t work, see this:
    https://kb2.adobe.com/cps/857/cpsid_85711.html
    I know that it doesn’t specifically mention your issue, but the nderlying issue for that document might also cause the symptom that you’re seeing.
    Also, it’s usually a good idea to give details about your computer when asking a question, starting with operating system and amount of RAM.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Linda Carpenter
    September 20, 2011 at 2:49 pm
    Thank you!
  • Todd Kopriva
    September 20, 2011 at 8:12 pm
    Which one worked?
  • Linda Carpenter
    September 26, 2011 at 11:38 pm
    Restarting my computer. I was too embarrassed to admit I had overlooked the most basic of computer rules. 🙂
  • Kieran Finney
    November 21, 2012 at 2:01 pm
    I’m jumping in here to re-start this thread because I’m having the same problem. And I did all the usual things, as in: clear preferences, run disk utility, restart mac, zap pram, pray to Steve Jobs, etc. No change.
    I am running CS6 on OSX 10.8.2. I have a mid 2010 Mac Pro with 2 x 2.4 Quad-Core, 12GB ram, ATI Radeon HD 5870 w/ 1GB ram, 2TB System hard drive, 6TB Raid 0 and 8TB e-sata Back-up. There is also a Matrox MXO2 LE w/ MAX connected via internal card, and a Sonnet Raid controller.
    I’m also using FCP 7. Not relevant, just thought you might like to know (I use a Euphonix MC Color controller for Color, and Apple hasn’t done anything even close with FCP X)
    I think I also get this error trying to do camera tracking.
