Activity › Forums › Adobe After Effects › After Effects warning: memory inefficiency
  • After Effects warning: memory inefficiency
    Posted by Bran Dougherty-johnson on May 16, 2005 at 11:56 pm
    I am getting this messge when I close my project:
    After Effects warning: memory inefficiency due to 4 unbalanced layer checkouts
    And I have to keep closing it because it is getting very slow and I also am having problems RAM previewing…
    Purging the memory doesn’t seem to help.
    I just installed and am using dv Matte Pro in this project.
    Nothing else has changed in my setup which has been very solid for a while.
    Anyone else seen this?
    Bran
    Bran Dougherty-johnson replied 21 years, 4 months ago 3 Members · 3 Replies
  • Bobby Walker ii
    May 17, 2005 at 3:57 am
    First, I’d delete DVMattePro and see if the problem persists. It it does I’d then trash the AE preferences and go from there. I must say, however, that I’ve been using DVMatte Pro since it came out and have never had a problem with it. Of course, I’m on a Mac and you didn’t say what platform your using and your profile just shows that your a US citizen.
    hth–
    bobby walker ii
    broadcast video COW
    G5 2.5GHZ DP,2.5 RAM, AJA IO LA, Medea G-Raid,FCP HD
  • Greg
    May 17, 2005 at 9:26 pm
    i have had the same warning with projects using dv matte pro on a 2.0 g5
  • Bran Dougherty-johnson
    May 18, 2005 at 2:22 pm
    I have upgraded AE to 6.5.1 and now my Ram Preview is no longer slow…
    And if I disable DV Matte Pro I don’t get the warning anymore.
    So that’s the culprit.
    Oh well.
    Maybe they’ll fix it, because it does seem to give good results for DV footage.
    AE 6.5.1 on a Dual 2.0 Ghz G5 3.5 GB RAM
    Thanks for the responses,
    Bran
