Activity Forums Adobe After Effects After Effects warning: invalid numeric result (divide by zero?) Expression disabled.
  • After Effects warning: invalid numeric result (divide by zero?) Expression disabled.
    Posted by Garrett Patten on April 5, 2011 at 8:09 pm
    I have been having a problem with an expression that is getting extremely frustrating. It is an expression that I have used on countless other projects with no problem, but for some reason, on this one specific project, it keeps giving me this error:
    The expression is being used on the scale property of about 50 or so layers. The expression that I am using is as follows:
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){
    t = 0;
    }else{
    t = time – key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
    amp = .05;
    freq = 2.0;
    decay = 10.0;
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value;
    I have tried changing the values of amp, freq, and decay to no avail. If anyone can offer any help or insight into this problem it would be greatly appreciated.
    Samuel Chrisna replied 11 years, 8 months ago 5 Members · 6 Replies
  • Spencer Tweed
    April 5, 2011 at 10:59 pm
    I know very little to nothing about coding, but the only time I have gotten this error is when I literally just divide by zero (rocket science, I know). With that in mind I would bet that your error is in here:
    because that is the only place that you divide, except earlier when you divide by 10…
    instead of dividing by Math.exp(decay*1) try just sticking a random number in there and see what happens:
    value + v*amp*Math.sin(freq*t*2*Math.PI)/5
    – Spencer
  • Samuel Chrisna
    February 21, 2013 at 2:25 am
    this is so awful.. so i have to go back to CS5 to do some bouncy expressions.. 🙁 if i put some random number in there, it wont stop.. does anyone have a solution?
  • Spencer Tweed
    April 22, 2013 at 1:38 am
    Sorry, you’ve exceeded my high-school math abilities… Good luck! You might want to check out the release notes of CS6, because it is really weird that it works fine in 5.5. I think I remember some expression things may have changed since then though…
    – Spencer
  • Tiago Casais
    July 5, 2013 at 12:22 am
    cheers,
    I had the same problem before.
    Try converting the expression to keyframes. It worked for me.
  • Aaron Jacob willman
    August 13, 2013 at 11:21 pm
    i saw this in another thread:
    https://forums.creativecow.net/thread/227/19701
    via Dan Ebberts –
    change
    if (n>0){
    to
    if (n > 0 && t < 1){
    and your bounce will work, even in CC.
  • Samuel Chrisna
    December 15, 2014 at 10:32 am
    yieeyy it works! thank’s man!
