Activity Forums Adobe After Effects After Effects warning: Couldn’t open Quicktime video output component
  • After Effects warning: Couldn’t open Quicktime video output component
    Posted by Brian Charles on July 27, 2005 at 10:19 pm
    I’m running OS X 10.4.2 and can’t use firewire preview.
    When AFX launches I get this message:
    After Effects warning: Couldn’t open Quicktime video output component.
    I have a G5 with a Sony DVMC DA2 which has worked well up to 10.3.9. The device is correctly identified in the System Profiler but neither AFX or FCP see it.
    I wonder whether this is an issue with QT 7.
    Jonathan Miller replied 21 years, 2 months ago 2 Members · 3 Replies
  • Jonathan Miller
    July 28, 2005 at 1:28 am
    Yes, the same happened to me as well. Luckily, it’s an easy fix. Just follow the directions and you’ll be previewin’ in no time!
    https://docs.info.apple.com/article.html?artnum=301852%3E
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
  • Brian Charles
    July 28, 2005 at 2:55 pm
    Actually had tried this. Removed receipts and re-installed AT 7.
    FCP previews work fine but AFX continued to give the error message and refused to see the Firewire output.
    Trashing AFX prefs solved the problem.
  • Jonathan Miller
    July 28, 2005 at 3:46 pm
    Cool. Glad it’s working for you now.
    Jon
