Activity Forums Adobe After Effects After effects warning: Audio conforming failed check media cache preferences
  • After effects warning: Audio conforming failed check media cache preferences
    Posted by Scott Miller on January 13, 2009 at 5:00 pm
    I have just loaded in Adobe CS4 Master Collection on my HP. When I boot up After effects I receive this warning.
    “After effects warning: Audio conforming failed check media cache preferences”
    When I preview audio After effects crashes. Does anybody have any suggestings?
    Rahul Aravind replied 8 years, 2 months ago 4 Members · 4 Replies
  • Franco Andrade
    June 23, 2009 at 1:47 pm
    I’m having the same problem, and I dont have a clue how to solve it.
  • Franco Andrade
    June 23, 2009 at 1:53 pm
    I solved it!
    Go to Edit -> Preferences -> Media & Disk Cache
    There, change the folders of Conformed media cache, maybe to another hard drive. I also checked the box Enable Disk Cache.
    It solved for me.
  • Ram Bal
    September 11, 2010 at 8:15 am
    I got the following error on a couple naughty Cineform avi’s (from canon dslr) when working in AE — and I didn’t even import the audio from Premiere Pro! Unfortunately, you can’t render these video files while you get this error.
    “audio conforming failed for the following file: (my video name).cfa. perhaps due to disk space.”
    The solution was simple — just separate out the video from audio with VirtualDub (and in my case, replace the original video file since I didn’t need the audio and wanted AE to link to the same video). No more render problems. Just thought I’d post it here for posterity.
  • Rahul Aravind
    July 3, 2018 at 12:22 pm
    Thanks!! It worked for me.
    But my case was different. I was getting this error message after I changed the Cache directory to a different one. Once I reset to the default directory, it worked!
    The solution is the same but case was different.
    Rahul Aravind
    https://www.instagram.com/rahularavind_photography
    http://www.rahularavind.com
