Activity Forums Adobe After Effects After Effects Warning
  • After Effects Warning
    Posted by Cutter Johnston on October 24, 2010 at 12:05 am
    I am getting this warning when I perform a RAM preview of about 160 frames with the audio added into the animation:
    After Effects warning: Q::MonitorMixerFailure fails with message: AsioHost::IntBuffers()failed
    Has anyone seen this? Can someone point me in the direction of a solution?
    Cutter Johnston replied 15 years, 11 months ago 2 Members · 2 Replies
  • Butch Golden
    October 26, 2010 at 5:22 am
    Need more info.
    What version of CS? What sound card, and what opsys. Further, what file format is the audio in?
    ASIO is probably not the problem but a unhealthy mix of the factors above can be.
  • Cutter Johnston
    October 26, 2010 at 12:02 pm
    Thanks Butch. I will examine the “unhealthy mix”. If I can not solve it I will return to the forum.
