Activity › Forums › Adobe After Effects › After Effects vs. Photoshop color issues
  • After Effects vs. Photoshop color issues
    Posted by Toosday on September 8, 2005 at 6:58 pm
    Hi. I took an Adobe Photoshopo CS2 file into After Effects 6.5 Pro and rendered a movie out of it. (After it was animated, of course.) I did this so that I can create a transition in DVD Studio Pro. However, the colors in Photoshop and After Effects are slightly different (one is slightly lighter). I made sure they are both RGB. Is there anything I can do to fix this problem? Thanks!
    Mylenium replied 21 years ago 3 Members · 2 Replies
  • Bill Clotz
    September 8, 2005 at 7:31 pm
    You probably need to disable the “color profile” in photoshop. Color profiles cause the colors to appear differently in photoshop than they really are.
  • Mylenium
    September 8, 2005 at 8:17 pm
    [Zarxrax] ”
    You probably need to disable the “color profile” in photoshop. Color profiles cause the colors to appear differently in photoshop than they really are.”
    Yeah, that could be possible. Other than that also simply try another CoDec. Certain CoDecs will automatically limit color ranges without telling you anywhere.
    Mylenium
    [Pour Myl
