Activity Forums Adobe After Effects After Effects Unexpected quit after install QuickTime 7 and Divx codec in windows XP pro sp2!
  • After Effects Unexpected quit after install QuickTime 7 and Divx codec in windows XP pro sp2!
    Posted by Dvjimmy on June 7, 2005 at 6:29 am
    Hi :
    Is anyone like me experience this kind of wired After effects 6.5.1 pro unexpected quit problem?
    After I install Divx codec or QuickTime 7 player (QT 6.5.2 was no problem), then open AE pro 6.5.1, click import or open project command, and the whole AE 6.5.1 just unexpected quit without any reason. Anyone here can give any suggestion to fix this problem? So far, I un-installed the Divx codec and install back the QT 6.5.2. The AE pro 6.5.1 runs smooth and normal on my workstation. If I install the divx and QT 7 again, AE unexpected quit again.
    Not sure this problem relate to Graphic card driver or not!
    Please help!! And Thanks your big help and time.
    Here is my system spec.
    Dual Xeon CPU 3.2Ghz (800 MHz system bus/ FSB)
    2GB RAM
    Four DIMM sockets registered ECC DDR 266/333 memory
    IntelR E7525 Chipset
    1: x16 PCI-Express (Slot 6)—>PCI-Express Graphic card / NVIDIA GeForce 6600GT 128MB RAM
    2: PCI 33 (Slot 5)————>FireWire Card
    3: x4 PCI-Express (Slot 4)—->
    4: PCI 33 (Slot 3)————>Audio Card / Aureon X File 1723 (www.terratec.com.tw)
    5: PCI-X 64/66 (Slot 1)——->Raid control IO Card / Intel SRCS14L
    dvjimmy
    Andrew Cooper replied 21 years, 3 months ago 3 Members · 2 Replies
  • Chris S
    June 7, 2005 at 1:09 pm
    I just had this happen to me on my MAC. I installed FCP5 this weekend which requires QT7. Last night was the first time I had to use my AE and everytime I tried to import video in, AE crashed. Infact I could not see my video in preview in my folders, and if I tried to preview it closed my folder. I could double click and play my file in the QT player though.
    Any solutions, ideas would be great
    G5, Panther, QT7, AE 6.5, FCP5.
  • Andrew Cooper
    June 7, 2005 at 5:50 pm
    I had this problem a while ago when I updated my Nvidia GeForce drivers – AE just disappeared with no error message when I tried to import a file.
    I reverted to an older version of the GeForce drivers and the problem went away.
