Activity › Forums › Adobe After Effects › After Effects “Uncompressed” Export problem.
Posted by Marlontorres on August 12, 2005 at 1:31 amHi, I’m having some problems with exporting out from After Effects. I put all settings at max quality and uncompressed but the footage still doesn’t look nearly as good as the original. I figured since its “uncompressed”, I shouldnt lose any quality right? Heres is a sample below of the problem and “jaggies” ive run into.
Marlontorres replied 21 years, 1 month ago 3 Members · 7 Replies -
John Dickinson
August 12, 2005 at 2:21 amIn the Premiere shot I can see a comb-like effect on the hand which indicates fields but I don’t see that on the AE render. Are you separating the fields on import and rendering to fields on output? It looks like you may separating the fields but not field rendering?
JD
John Dickinson
Motionworks
https://www.motionworks.com.au -
Marlontorres
August 12, 2005 at 2:24 amthe original uncompressed Premiere Pro file is Lower Fields, and I export in Lower Fields. Is there anything else I missed? Also, when watch the files side by side seperately, the After Effects uncompressed file is stretched out slightly. What’s causing this?
John Dickinson
August 12, 2005 at 2:29 amSo you are separating the fields on import into AE and rendering out Lower Field First from AE? The stretch sounds like a pixel aspect ratio issue. Check the footage resolution and pixel aspect ratio and check that the comp size and pixel aspect ratio matches. Also make sure you aren’t stretching the render in Output Modules (Render Queue).
JD
John Dickinson
Motionworks
Marlontorres
August 12, 2005 at 2:31 amyes on the first question. for the second, im using 720×480 DV NTSC 0.9 on everything, so it can’t be that. and i definitely have “stretch” unchecked on the queue. what else could it be? its driving me nuts
John Dickinson
August 12, 2005 at 2:42 amTry rendering to a different codec or maybe use a TGA sequence and see if the problem is still there.
John Dickinson
Motionworks
Jim Zito
August 12, 2005 at 3:13 amJust to make sure–you are rendering at Full Resolution and Best Quality right?
