Activity Forums Adobe After Effects After Effects transition help
  • Adinnin
    May 17, 2007 at 11:40 am
    At first look you could do most of that using animated masks..
    the swirl, were not re-shaping that much, just moving left to right..
    and by the looks of things they had only animated the big ones once and then just moved their position..
    once you have a few of those.. you can also use them as masks.. with a bit of clever pre comping
    Alex
  • Front242
    May 17, 2007 at 5:13 pm
    Hi Alex,
    Thanks so much responding. So if I go in and make those swirl shapes with animated masks I can then duplicate, resize and reshape them? I was thinking that the plugin, that had at least a template for those nice wipes, was digital trove PRIME which has a swirl/ push effect, but I couldn’t get it working correctly. The swirls are so smooth and shaped well I though it had to be a plug-in customized. Any other tips you can offer I’d really appreciate as I’m a newbie!
    Thanks again.
