Activity › Forums › Maxon Cinema 4D › After Effects towards C4D
  • Emmet Reddy
    January 12, 2010 at 11:04 am
    Try vectorizer in primitives or else make a work path in photoshop then export work path as an illustrator file open in c4d and you can add extrude to this.
  • Aymeric Gardey
    January 12, 2010 at 1:36 pm
    Hello Emmet
    Thanks for your interesting answer.
    There is one problem. I don’t how can I apply the initial texture from After Effects(or photoshop) to C4D.
    Now I arrive to extrude but to put the initial texture.. I don’t how
    It’s not really a texture because it’s textes and 1 object.(with transparency space..)
    Am I clear?
  • Emmet Reddy
    January 13, 2010 at 5:34 pm
    Can you send the image im not too clear?
  • Aymeric Gardey
    January 13, 2010 at 6:15 pm
    Here my image that I want to apply on a the extruded path.
    https://www.inspiration-productions.com/aucoeur.png
    Here the result that I’d want from a png file or other way
    https://www.inspiration-productions.com/aucoeur-result.jpg
    Aymeric
  • Adam Trachtenberg
    January 13, 2010 at 7:23 pm
    No, you can’t extrude a bitmap directly — just splines. You can use the vectorizer object to derive splines from a bitmap and then extrude the vectorizer, but you’ll get cleaner results exporting the paths/splines from PS or creating them in Cinema.
