Activity › Forums › Adobe After Effects › After effects to run on more ram
  • Mark
    October 6, 2008 at 5:24 pm
    What OS are you using ???
    IN XP you have you to activate the /3GB switch in the boot.ini file, then in After Effects there is a setting to prevent DLL Fragmentation….this helps AE use bigger chunks of RAM.
    Here is a link that may help :
    https://generalspecialist.com/2006/05/using-more-than-2gb-of-ram-in-after.asp
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Ben Hawkins
    October 6, 2008 at 8:12 pm
    im using vista
    I got the hottest beats and the softest fur.
