Activity Forums Adobe After Effects after effects to PS3
  • after effects to PS3
    Posted by Dawud Ali on June 1, 2011 at 9:52 pm
    hi guys
    i want to put my renders project on PS3
    so that i could check how my piece looks on a tv.
    i know a short cut would be to get a mac to tv cable
    but i’m interested in finding a solution.
    i exported my project as a apple pro-res HQ so the file
    has a .mov format. i’m not well informed when it comes to formatting.
    thanks in advance for support
    Dawud Ali replied 15 years, 3 months ago 3 Members · 4 Replies
  • Spencer Tweed
    June 1, 2011 at 10:38 pm
    I know basically nothing about a PS3, but I believe that you can upload music and video to the hard drive just like to an ipod or other media device. I would encode the render to .mov with .h264 as the codec – most things should be able to interpret this. Then you upload the video just like anything else on the PS3 (not totally sure how to do this, but I’m sure it is simple).
    Hope that was what you were asking.
    – Spencer
  • Dawud Ali
    June 1, 2011 at 10:52 pm
    I already have a second version compressed it to .h264 so thanks for the tip i will try it
    many thanks
    normally you would open the usb under the appropriate menu e.g video, music or photo.
    then select usb and press display all and then icons are shown for each playable items. {*}
    press copy to copy to PS3
    at this stage {*} the problem arises my project file doesn’t show as it’s not recognised
  • Conrad Olson
    June 2, 2011 at 3:04 pm
    The PS3 won’t play .mov files. If your QuickTime is encoded in h.264 try just changing the extension from .mov .mp4, I can’t remember if that works. If not you can use QuickTime to export the file as an .mp4 without having to re-encode it.
    conradolson.com
  • Dawud Ali
    June 2, 2011 at 6:23 pm
    awesome i shall try it, sometimes i forget QuickTime has more uses
    thnks
