Activity Forums Adobe After Effects After Effects to Flash problem
  • After Effects to Flash problem
    Posted by Adinnin on May 17, 2007 at 10:51 am
    I have just finished a job using After Effects.. and the client has now decided that they need the final output as a flash file !!!
    I know I can export as a Flash file… but it the file size it outputs is quite large… and it doesn’t play to well.. (jitters)
    is there anyway around this.. if I export out and then find someone with Flash.. could they use my output and reduce the file size ??
    any ideas.. suggestions.. very welcome
    cheers
    Steve Roberts replied 19 years, 3 months ago 2 Members · 1 Reply
  • Steve Roberts
    May 17, 2007 at 3:25 pm
    Find someone with Flash, give them a file in Animation codec, then let them convert it to FLV (Flash Video) at a lower frame rate. You can also use Squeeze to do that. AE 8 should also do that, I think, when it comes out. 🙂
