Activity Forums Apple Final Cut Pro Legacy After Effects to Final Cut Pro Workflow
  • After Effects to Final Cut Pro Workflow
    Posted by Chris Tarroza on April 21, 2011 at 3:53 pm
    Like many I assume, I work between FCP and AE a lot: edit in FCP, create the graphic in AE, then import that graphic into FCP. As with any client work however, changes and revisions are just as certain as paying taxes. Though the changes may be little, I’d have to render out the whole graphic again which nibbles away little bits of my time throughout the day, adding up to huge amount of time wasted waiting around for a render to finish, not to mention having to re-export the sequence from FCP.
    I’ve also run into some problems when updating a render from AE. If I need to re-render a graphic, usually I delete the original video file in the Scratch (or wherever the file is in the Finder) and then render from AE with the exact same file name to the exact same place so that FCP still sees the file. For the most part it works though I I usually cross my fingers. However, if I change something like the duration of the video, FCP doesn’t pick up on it. Sometimes quitting and reopening FCP works, sometimes it doesn’t. Having to constantly close and reopen FCP is another time waster.
    Maybe I should do it the other way around and export the edited sequences from FCP and bring that into AE. Usually the changes need to be the graphic anyways. I work with ProRes 1080p footage so the graphics I render from AE are the same to save me from render times in FCP though I usually render out half-res or lower until its ready for distribution where I then render the full-res.
    The time killer is the constant rendering from AE. The headache is replacing the clip in FCP. You’d think that since the updated graphic has the same file name and is in the same folder, FCP could just pick up on the changes and off you go (the ‘Reload Footage’ in AE does just that) but no. Hopefully FCP X will have an easier way in dealing with this (unless there already is a way that I am unaware of).
    So experts, what is your workflow when working between the two? Looking for tips on efficiency and time-savers. Any suggestions would be greatly appreciated.
    Ernie Geefay replied 12 years, 8 months ago 10 Members · 18 Replies
  • 18 Replies
  • Jeremy Garchow
    April 21, 2011 at 4:04 pm
    [Chris Tarroza] “If I need to re-render a graphic, usually I delete the original video file in the Scratch (or wherever the file is in the Finder) and then render from AE with the exact same file name to the exact same place so that FCP still sees the file.”
    I usually just render over the the graphic right from AE, when AE asks to overwrite, I say yes. You can’t toggle back to FCP, while this process is happening as there won’t be a file to link to. You have to wait until the render is complete before returning to FCP. Once the render is complete and you return to FCP, the graphic will update.
    [Chris Tarroza] “Hopefully FCP X will have an easier way in dealing with this (unless there already is a way that I am unaware of).”
    If you have toggled back to FCP before the render is complete, right click the offline clip, and choose reconnect media, and click search.
    If you want a “for real” workflow between AE and an NLE, look to using Premiere, or using Motion for FCP. Either way, you are going to have to render, there’s no getting around that.
    Jeremy
  • Rafael Amador
    April 21, 2011 at 4:11 pm
    You can just click-Copy de new file and “Paste Attributes: Content” to the old graphic in the time-line.
    rafael
    http://www.nagavideo.com
  • David Heidelberger
    April 21, 2011 at 5:28 pm
    Hi Chris,
    What version of AE are you using? I’ve been working on a program that may help with this. I just added you as a cow-friend. Message me and we can discuss it.
    – David
  • David Prum
    April 21, 2011 at 6:50 pm
    Automatic duck makes an exchange program between FCP and AE. I don’t know if its worth the couple hundred bucks as i’ve never tried it. I guess if its good and you have the money and high enough volume of work/revisions then it would be.
  • Jeremy Garchow
    April 21, 2011 at 6:54 pm
    Just to clarify, you can go FCP to AE, but not AE to FCP.
    I have auto duck and it’s great to get to AE, but you always have to export a flattened movie out of AE. You cannot get back to an FCP timeline with the duck.
    Jeremy
  • John Kaley
    April 21, 2011 at 7:59 pm
    Is there any trick to this? I’ve wanted to do this type of thing FOREVER, but AE sends an error message: “unable to delete existing file”
    If I actually quit FCP, then AE renders fine. I’d love know your secret.
  • Hillary Knox
    I haven’t torture-tested it yet (and not to take anything away from Automatic Duck, which, in all fairness, I’ve never used)…but, I have had some pretty good success in the FCP > AE direction by using Premiere as an intermediate step. Export an XML from FCP, Import the XML into Premiere, save the Premiere project, go into AE, Import Premiere project. And viola, more or less. You might have to re-order or sort your layers based on in-point to give you something more like what you want, but maybe, maybe not. So far, for me, it’s worked pretty great.
    Don’t ask me about getting stuff back into FCP by the reverse method. I’m not saying it’s not possible, but I haven’t tried it.
  • Jeremy Garchow
    April 21, 2011 at 8:07 pm
    [John Kaley] “Is there any trick to this? I’ve wanted to do this type of thing FOREVER, but AE sends an error message: “unable to delete existing file””
    Make sure the file is not selected in the Finder/close all Finder windows.
  • John Kaley
    April 21, 2011 at 8:38 pm
    Thanks Jeremy, still no go. You must have some secret mojo with your computer.
  • Jeremy Garchow
    April 21, 2011 at 8:54 pm
    [John Kaley] “Thanks Jeremy, still no go. You must have some secret mojo with your computer.”
    Here’s my process.
    In AE, set the file to render, click on the file name in AE, navigate to the file in the Popup window, click on that file to accept the same file name. AE asks if it’s OK to overwrite, I say yessir. Render. Wait.
    AE render chime, toggle back to FCP and the file refreshes.
    Jeremy
