Activity Forums Adobe After Effects After Effects to FCP High Quality Render
  • After Effects to FCP High Quality Render
    Posted by Daniel Elder on September 3, 2008 at 10:41 pm
    I am doing a complex montage photo render, and I need it to be highest quality possible for the render + any other Advanced 3D settings or other settings to keep the images from pulsating would be helpful. I have been rendering the trial videos first as standard tiff 720 x 486, D1/DV NTSC Widescreen Pixel, then reimporting the image sequence and exporting those out for FCP at 720 x 486, D1/DV NTSC Widescreen Square Pixel, with the ProRes 422(HQ). That brings it in at the right format, and the video quality looks really good, but I wanted to see if I could get it even better with other techniques out there? Please, any advice would be helpful, thanks!
    Dan
    Daniel Elder
    producer
    http://www.luminair.com
    Joey Burnham replied 18 years ago 2 Members · 2 Replies
  • Daniel Elder
    September 4, 2008 at 2:40 pm
    I’ve tried using Lossless, and that didn’t have too much success either, any ideas? Thanks
    Daniel Elder
    producer
  • Joey Burnham
    September 4, 2008 at 6:00 pm
    If your working in NTSC D1, you shouldn’t have any problems just exporting simple pings, tiffs or targas?
    Where are you suffering quality loss?
