Activity Forums DaVinci Resolve After Effects to Davinci
  • After Effects to Davinci
    Posted by David Stretz on March 30, 2012 at 12:51 pm
    I took a few of my original clips & threw them into After Effects so I could use the “Neat Video” plug-in for noise removal. I rendered the AE files into a folder as Quicktimes.
    When I look for the files in Davinci they are no where to be found, every other file is there.
    Juan Salvo replied 14 years, 5 months ago 5 Members · 5 Replies
  • Brandon Thomas
    March 30, 2012 at 3:17 pm
    make sure the files have the ‘.mov’ extension, and tat you’re rendering out of after effects to a supported codec.
  • Erik Lindahl
    March 31, 2012 at 10:35 pm
    Perhaps also make sure timecode on your output-files from AE match the input.
  • Jay Bloomfield
    April 1, 2012 at 12:14 am
    Just because a file has a MOV extension doesn’t mean Resolve will display it in the list of files, even though it actually exists in that folder. The file must be in both a wrapper and encoded with a codec that Resolve will read. For example, Resolve just ignores DNxHD files with a MOV extension. It reads many other MOV files (Red, Cineform, H.264, etc.) with no problem. It will read DNxHD files in an MXF wrapper.
  • David Stretz
    April 5, 2012 at 6:21 pm
    how can you put something in an MXF Wrapper?
  • Juan Salvo
    April 5, 2012 at 6:56 pm
    Bring it in to Avid. Consolidate it to MXF.
    Additional twist is that there are different flavors of mxf.
    Sony’s MXF is different than Avids MXF.
