Activity Forums VEGAS Pro After Effects titling to Vegas using Lagarith codec: No Alpha?
  • After Effects titling to Vegas using Lagarith codec: No Alpha?
    Posted by Fotis Vassis on April 2, 2010 at 12:31 pm
    Hi, I ususally export my titling in AE using PNG image sequence or uncompressed avi and import them to Vegas (selecting premultiplied dirty as Alpha Channel).
    I decided to use the Lagarith codec to reduce the file size (uncompressed gets really big and image sequence spoils my folder’s tidiness!!)
    But I can’t get transparency with Lagarith. I make sure I select in AE export RGB + Alpha but I can’t get the tranparency/alpha to work.
    Is there something am I doing wrong?
    Thanks in advance
    John Rofrano replied 16 years, 5 months ago 3 Members · 3 Replies
  • Theo Van laar
    April 2, 2010 at 12:41 pm
    Just add the event with transpary to the time line and right-click on the event. Selecting the PROPERTIES option allows you to select the right transparancy setting for this event
    Theo
  • Fotis Vassis
    April 2, 2010 at 3:52 pm
    Thanks for the reply but I found the solution. In Lagarith configuration I must select RGBA and not RGB.
    Then import to Vegas, right click properties–>media and premultiplied dirty
    Regards from Greece
    Interchefs Culinary Club
    The Interactive Gourmet Experience
  • John Rofrano
    April 2, 2010 at 5:17 pm
    Alternately you might want to use the Quicktime Animation codec. It is specifically designed for exactly this kind of work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
