Activity Forums Adobe After Effects After effects time stretch problem
  • Craig Bower
    June 4, 2012 at 10:56 am
    Did you do some roto work? I hate when this happens. The only work around I’ve found for this is to render out the comp before the time stretch has been applied and then drop that movie into the comp and reapply the time stretch.
    Hope it helps.
