Activity Forums Adobe After Effects After Effects Text Light Up Effect
  • After Effects Text Light Up Effect
    Posted by Jake Krask on July 2, 2013 at 11:01 pm
    Hey. I could really use someones help. I have to make around 400 words where each letter will light up individually. Right now I make a text layer then turn it into a shape layer and take each letters opacity keyframe it to 0 move forward one frame and increase to opacity to 100. Then I move forward two seconds and continue this process. This is a really long and annoying process and I was wondering if you know of an easier way to do this. Please help it takes me about 5 minutes and I really could use an easier way.
    PLEASE HELP.
    Thank you
    Ridley Walker replied 13 years, 1 month ago 3 Members · 4 Replies
  • John Cuevas
    July 3, 2013 at 1:20 am
    You need to look into text animators. Make sure your “Effects & Presets” window is open(cnlt+5)and in the search box type in “Fade Up Characters”. Drag that on to a text layer and it should do automatically what you are doing manually. You’ll probably need to adjust the keyframes a bit, but that preset should get you 90% of the way home.
    Next you should check out: Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC), the link to Andrew Devis training at the Cow, has quite a few lessons on text animators, would be very helpful to what you are doing
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jake Krask
    July 3, 2013 at 1:33 am
    Thank you so much. Do you know if there is a way to not get each letter to fade in but rather just pop up. I know I could make a lot of keyframes to get what I want but I was wondering if you knew of an easier way from here?
    Thanks so much!!
  • John Cuevas
    July 3, 2013 at 2:36 am
    Open up your text and if you used the preset you want to open up Animator 1″ > Range Selector > Advanced and change the smoothness from 100% to 0%. That will manually change the effect. There is another preset called “typewriter” you could use that is setup exactly like that though.
    Thinkck.com
  • Ridley Walker
    July 3, 2013 at 4:18 am
    I would highly recommend this preset which can be easily modified to produce virtually any sort of procedural type animation you want.
    https://mattrunks.com/en/tutorials/after-effects/amortype
