Activity › Forums › Adobe After Effects › After Effects – Templates Projects
Posted by Denis Fouché on October 30, 2006 at 10:31 pmHi,
Does anybody know how do we make some templates projects (.aet) from an After Effects project (aep) ? Thanks ! DenisChris Burns replied 19 years, 10 months ago 4 Members · 4 Replies -
Mylenium
October 31, 2006 at 9:55 amNo, you can’t do that. That ground is exclusive Adobe territory. ;o)
Mylenium
[Pour Myl
Michael Munkittrick
October 31, 2006 at 3:15 pmHere’s an article that will explain the process. It’s essentially as simple as saving your project via the “save as” command and changing the suffix to .aet. Then the compositions within that project will function as templates that will be ready for modification. Bear in mind that when you save a template file, any changes you make to said template will disolve if you fail to resave the template again. I typically save it with an alternate name and a version number to let me cycle through them quickly.
https://www.dv.com/news/news_item.jhtml?articleId=191203985
Michael Munkittrick
Gainesville, Florida USA -
Mylenium
October 31, 2006 at 5:49 pmYes, simply renaming will give some functionality, but I think he was more after having those previews which you can’t do that way. ;O)
Mylenium
[Pour Myl
Chris Burns
October 31, 2006 at 8:59 pmWhat is the difference between an .aep and an .aet? And what the purpose would be?
