Activity Forums Avid Media Composer After effects Supers with Alpha to AVID
  • After effects Supers with Alpha to AVID
    Posted by David Andrews on September 21, 2009 at 7:58 pm
    I need some quick advise. I do not use avid much but another department that I am teaching after effects in does. Last year I showed a group and I thought Avid took avi files with alphas. I need to bring in a simple super designed in AE CS3 with Alpha intact. I see Avid takes quicktime which is great but even when I put invert in the effects editor it doesn’t work right. How do you get a composite from AE into Avid? I also tried a PNG sequence but Avid does not seem be able to bring the sequence in.. Any suggestions.
    David
    Michael Hancock replied 16 years, 12 months ago 4 Members · 3 Replies
  • Ed Cilley
    September 21, 2009 at 8:47 pm
    If you are creating the file in AE, you could render with the Avid codec and then you would import straight into the Avid. If not, you would invert the alpha. And yes, it does work with most types of QT.
    Avid will also import a PNG sequence. Select the first file of the sequence and then in the options box, choose “Autodetect Sequentially-Numbered files”. Again, you will need to choose to invert the alpha.
    Hope that helps.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Kenton Vannatten
    September 26, 2009 at 3:17 am
    Avid codecs do not support Alpha.
    So, set up your AE to Render out to Animation with Alpha, then in Avid set the Import options to Invert Existing and RGB color space.
    Kenton VanNatten
    Avid Editor (for hire)
  • Michael Hancock
    September 26, 2009 at 4:29 am
    [Kenton VanNatten] “Avid codecs do not support Alpha.”
    Some of them do.
    ALPHA SUPPORT:
    Avid Meridien Uncompressed
    Avid Meridien Compressed
    Avid DNxHD
    NO ALPHA SUPPORT:
    Avid 1:1x
    Avid DV
    Avid DV100
    Avid MPEG50
    Michael
    I’ll be working late.
