Activity Forums Adobe After Effects After Effects – spotlight not showing
  • After Effects – spotlight not showing
    Posted by Lily Baker on April 4, 2015 at 3:49 pm
    I have done this before, but for some reason I can’t recreate the effect.
  • I have a black solid layer (3D, z-index positioned further back) and a light layer (spot).
  • I do not have draft 3D on, and my layers are set to 3D.
  • I’m sure it’s something simple but I can’t seem to find the answer anywhere online.
    Thank you!
Steve Earthling replied 6 years, 10 months ago 4 Members · 5 Replies
    • Richard Herd
      April 6, 2015 at 4:49 pm
      I don’t understand what you’re trying to do.
    • Lily Baker
      April 7, 2015 at 5:17 pm
      I’m just trying to create a spotlight on a black solid, but not seeing the light.
    • Richard Herd
      April 7, 2015 at 10:20 pm
      [Lily Baker] “I’m just trying to create a spotlight on a black solid, but not seeing the light”
      There’s you’re problem. If you light black, it is black. And it will look like nothing.
    • John Cuevas
      April 8, 2015 at 1:09 pm
      Create a white solid, it will be black in the areas that the spotlight doesn’t hit and be white where it’s lit up.
      Johnny Cuevas, Editor
      Thinkck.com
      “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
      —THOMAS EDISON on inventing the light bulb.
    • Steve Earthling
      October 7, 2019 at 7:29 pm
      Want to say thanks for the solution since the original guy who posted did not have the courtesy to do so. Thanks!
