Activity › Forums › Adobe After Effects › After effects/ Sony Vegas
  • After effects/ Sony Vegas
    Posted by Maëlle Jumel on August 29, 2016 at 8:38 am
    Hi everyone,
    I’ve wanted for a while to be able to transfer my projects from Vegas to AE with the effects and everything.. It’s probably not possible since the effects aren’t the same (although they’re quite similar) but I thought I’d post something here to know if there’s a possibility even to find an alternative : what I’m really trying to do is to transfer my effects preset (a coloring preset I’ve made on Vegas) to AE.
    Is there any chance it’s possible?
    Thanks a lot
    Walter Soyka replied 10 years, 1 month ago 2 Members · 3 Replies
  • Walter Soyka
    August 29, 2016 at 5:08 pm
    How did you make the coloring preset in Vegas? Not everything will be a direct translation, but maybe we can get you close.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Maëlle Jumel
    August 29, 2016 at 5:25 pm
    Ok so what I did was that I applied every effect that I liked and looked good, altered them the way I wanted and then hit the fx button and clicked save as on the right!
    Asus Windows 10 PC
    Intel Core i5 6300HQ CPU 2.30GHZ
    RAM 8GB
    Nvidia GeForce GTX 960M
  • Walter Soyka
    August 30, 2016 at 9:52 am
    I doubt we’ll be able to automatically translate that. I see two options:
    1) Describe what specific effects you used in Vegas and we can point you to similar or equivalent effects in Ae.
    2) Use Red Giant LUT Buddy to build a LUT that describes your look in Vegas and apply it in Ae. You’ll have to write the LUT pattern onto a piece of footage in Ae, render, import to Vegas, apply your preset, render, import to Ae, and read the LUT pattern before exporting a LUT:
    https://www.redgiant.com/tutorial/getting-started-with-magic-bullet-lut-buddy/
    Walter Soyka
