Activity Forums Adobe After Effects After Effects settings
  • After Effects settings
    Posted by Argaemge1 on September 11, 2007 at 4:30 pm
    Hello! Mr Aharon Rabinowitz
    first I’d like to say that you do a realy good work creating this tutorials and I’m thinking of buying a couple of your dvds… but the reason for messageis is that I run across a problem when I was workin with the “Creating a Cartoon from video” tutorial; Everything worked out good but the only thing is that now my footage,images come out with two red lines across them when I export the files from After effects into any format,that started to happen after I inported the files into illustrtor from After Effects while working with the “Creating a Cartoon from video” tutorial.
    The problem,and for some reason is that I can’t change it back….any ideas?
    I dont have a lot of experience with After Effects so if you can help I’ll thank you very much and GOD bless!
    Sean Hellwig replied 19 years ago 2 Members · 3 Replies
  • Sean Hellwig
    September 11, 2007 at 6:50 pm
    Can you post a screenshot please. Also, what are you system specs? using any demo plugins?
  • Argaemge1
    September 12, 2007 at 5:17 am
    Hello Mr. seandon01!
    Demo plugins!!! that was the key word, not sure which one was creating the problem so I’ took’em all out and it took care of the problem.
    Thanks for your help you guys are great and GOD bless all!!!
  • Sean Hellwig
    September 12, 2007 at 5:30 am
    Great! I’m glad that helped… Many unregistered and demo plugins produce a watermark upon the final rendered output. This forum really is the best. Any question you have has either been answered already, or will be answered. It’s so great! Have fun man!
