Activity › Forums › Adobe After Effects › After effects seems to take a long time to render
  • After effects seems to take a long time to render
    Posted by Rod Field on December 14, 2011 at 8:35 am
    After effects seems to hang or take a long time to render, I took a look at the resource monitor on windows 7 and then took a look at the wait chain on the after effects.exe and got the message ‘one or more threads of after effects.exe are waiting to finish network i/o, the box underneath that read ‘after effects.exe (PID:8216) Thread: 7216. Does anyone know what that means and how to get after effects.exe to run normally ?
    Shayan Khaliq replied 13 years, 3 months ago 4 Members · 3 Replies
  • Hosein Alfa
    December 14, 2011 at 1:20 pm
    go to preference and change option “Multiple render”
  • Walter Soyka
    December 14, 2011 at 2:14 pm
    Are you rendering to QuickTime? AE does use the network stack to get around the lack of 64-bit QuickTime support by communicating with a 32-bit QuickTime helper application.
    If this is the problem, make sure your firewall is allowing QT32Server.exe, or try rendering to AVI.
    Walter Soyka
  • Shayan Khaliq
    June 8, 2013 at 4:19 am
    I realize this is an old post but putting this up for any readers that stumble here with the same issue.
    Seems this is caused by CPU performance (or lack of it) I noted that my CPU usage for both cores (Task Manager > Performance) jumps to about 65% whenever i make a small change to the Comp. (adding effects etc). It takes easily about 20-25 secs to render. I’m using an AMD X2 250 dual core, with 4GB ddr3 RAM.
