After Effects scripting – convert audio to keyframes?
How can you do “convert audio to keyframes” using scripting in after effects, manually you would right-click on the “sound” layer > keyframe assistant > convert audio to keyframes.
var myComp = app.project.activeItem;
var musicComp = myComp.layer("music");var myEffect = musicComp.property("Effects").addProperty("High-Low Pass");
myEffect.property("Filter Options").setValue(1);
myEffect.property("Cutoff Frequency").setValue(50);// then I want to do "convert audio to keyframes"
thanks.
