Activity Forums Adobe After Effects Expressions After Effects Scripting – Check to see if layer has separated dimensions
  • After Effects Scripting – Check to see if layer has separated dimensions
    Posted by Kevin Snyder on May 11, 2022 at 8:57 pm
    What would be the correct way to create an If Else statement to check a layer for separate dimensions? The statement that I’m using now actually changes the layer’s position property, but I want to run two different functions based on the position separated dimensions property.
    Dan Ebberts
    replied 4 years, 4 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    May 11, 2022 at 10:59 pm
    Like this, I think:
    if(myLayer.property("Transform").property("Position").dimensionsSeparated){
    // do something
    }else{
    // do something different
