Activity › Forums › Adobe After Effects Expressions › After Effects Script – loop through selected items
Posted by Stephen Kennedy on January 21, 2012 at 9:15 amHi,
I’ve just started trying to write my first script for AE. Have managed to cobble together a script that executes fine for a single selected item, but I can’t seem to find a way to build a for loop to execute the script for every selected item. The script simply takes the item (which will be an image sequence), places it in a new 1920×1080 comp, adds a Transform effect and rescales to 150%. Can anyone help me build a loop for this?
Here is the code:var mySelection = app.project.activeItem
var myComp = app.project.items.addComp(mySelection.name, 1920, 1080, 1, mySelection.duration, 24)
var myLayer = myComp.layers.add(mySelection)
var myTransform = myLayer.Effects.addProperty("Transform")
myTransform.property(4).setValue(150)Avinash Ramanath replied 7 years, 12 months ago 5 Members · 15 Replies -
Dan Ebberts
January 21, 2012 at 9:41 amThis should work:
var mySelectedItems = [];
for (var i = 1; i <= app.project.numItems; i++){
if (app.project.item(i).selected)
mySelectedItems[mySelectedItems.length] = app.project.item(i);
for (var i = 0; i < mySelectedItems.length; i++){
var mySelection = mySelectedItems[i];
var myComp = app.project.items.addComp(mySelection.name, 1920, 1080, 1, mySelection.duration, 24);
var myLayer = myComp.layers.add(mySelection);
var myTransform = myLayer.Effects.addProperty("Transform");
myTransform.property(4).setValue(150);
Dan
Stephen Kennedy
February 1, 2012 at 12:20 pmThis works perfectly, thank you so much for your help.
S -
Amir Aizat
October 4, 2017 at 10:01 pmI hate to be the guy that revives a really old thread, but this is relevant to what I’m doing.
I’m trying to create a simple script that toggles the motion blur switch for all layers of selected comps. I can’t get it to work because I don’t really understand how to store/call items in an array. I’ve been cracking my head over it and I still don’t get it.
Posting my code here because the expressions code box can be wonky with ‘<‘
var proj = app.project;
var selectedItems = [];for(var i = 1; i <= proj.numItems; i++){
if(proj.item(i).selected){
selectedItems[selectedItems.length] = proj.item(i); //store selected items in an array? how does this line even work? why .length? why not +=?
}for(var h = 0; h < selectedItems.length; h++){ //loop through all stored selected items in the selectedItems array. .length makes sense to me here.
for(var c = 1; c <= selectedItems[h].numLayers; c++){ //loop through all layers of the stored item.
selectedItem[h].layer(c).motionBlur = 1; //do this for all layers.
Dan Ebberts
October 4, 2017 at 11:10 pmI think this works:
if(proj.item(i).selected && (proj.item(i) instanceof CompItem)){
selectedItems.push(proj.item(i));
}var myComp;
var myLayer;
for(var i = 0; i < selectedItems.length; i++){
myComp = selectedItems[i];
for(var j = 1; j <= myComp.numLayers; j++){
myLayer = myComp.layer(j);
if (myLayer.hasVideo){
myLayer.motionBlur = true;
Prateek Chaturvedi
December 1, 2017 at 7:19 amHi all,
Actually I am selecting the item through the script given in adobe script after effects guide
var firstComp = app.project.item(1);
alert(“number of layers is ” + firstComp.numLayers);
alert(“name of last layer is ” + firstComp.layer(1).name)the alert is showing right when I run the script but as soon as i change the order of name the alert shows message undefined . So I want to know how the item is taken in order .
Could anyone guide me through this.var firstComp = app.project.item(1);
alert("number of layers is " + firstComp.numLayers);
alert("name of last layer is " + firstComp.layer(1).name) -
Avinash Ramanath
September 21, 2018 at 4:13 pmHi Dan.
In the below code that you have shared. Can you modify it to do the following:
If image set comp duration as 4 seconds
If video set comp duration = mySelection.durationThanks
Dan Ebberts
September 21, 2018 at 4:23 pmAssuming that all selected items are video or images, I think you’d just have to check if the item’s isStill attribute is true.
Dan
Avinash Ramanath
September 21, 2018 at 4:38 pmis it like this?
var mySelection = mySelectedItems[i].isStill = "true";
Dan Ebberts
September 21, 2018 at 4:41 pmMore like this, I think:
if (mySelectedItems[i].isStill){
var myComp = app.project.items.addComp(mySelection.name, 1920, 1080, 1, 4, 24);
}else{
Dan
