Activity Forums Adobe After Effects After Effects replace multi fonts
  • After Effects replace multi fonts
    Posted by Rockey klide on March 5, 2026 at 4:48 pm
    Hi
    i have a project with lots of text layers that i need to change the fonts
    what is the best way to replace them at once and not one by one?
    John Martin
    replied 6 months, 1 week ago
    2 Members · 6 Replies
  • John Martin
    March 5, 2026 at 6:11 pm
    hey Rockey! i recorded a tutorial for you with the solution, lemme know if you appreciate it!
    https://youtu.be/irm_WDRaThA
  • Rockey klide
    March 6, 2026 at 9:48 am
    That’s working for active comp but i have layers in other comps.
    i want to replace them at once and even better if i can control which one to change and which to keep the same
  • John Martin
    March 6, 2026 at 11:09 am
    I see! Ok i’ll escalate this and use the big guns, give me some hours and i’ll send you something new! 🔥
  • John Martin
    March 6, 2026 at 6:07 pm
    i worked all afternoon to code this, now it does what you asked, lemme know if you like it!
    https://youtu.be/DAxiRVOgeqc
  • Rockey klide
    March 8, 2026 at 9:30 am
    Hi
    thanx for the script but it solve some of the problem i have 20 comps with different layers and fonts and want to change some of them and not all also some i just need to change the color
  • John Martin
    March 8, 2026 at 4:17 pm
    sure to avoid changing the font just avoid selecting the comps before running the script;
    for the colors instead i can sit down for another afternoon and make the script also ask about the color of all the texts of each selected comp. Sounds good to you?
