Activity Forums Adobe After Effects After Effects Renders Out Choppy Video
  • After Effects Renders Out Choppy Video
    Posted by Adam Kois on April 23, 2012 at 7:56 pm
    All of the sudden my project went to rendering out normal looking video to choppy stuff. I have checked all the frame rates and for all of my comps and rendering they are set to 29.97fps.
    Also when I preview the render inside after effects it plays perfectly. Even while rendering I can see that it is rendering every frame that I want to. Some how though when I play the quicktime file back it is all choppy. Now it isn’t a play back issue I don’t think, since it is only a H.264 file and is very small… all the previous renders played back fine.
    Now, here is when the problem started. I originally had my comps set to 720p and changed them all to a custom dimension. Changed some elements around, and everything was fine. Rendered a test and previewed fine. Then I went and did some more work on the project and all of the sudden every render is now choppy.
    Also now my character that I have a walk sequence on will sometimes disappear… and only if i preview it back in half res will he show up… very weird…
    Please help, I cannot figure out what is wrong.
    Antonio Mars replied 10 years, 8 months ago 2 Members · 4 Replies
  • Adam Kois
    April 23, 2012 at 9:54 pm
    No the issue is not the playback I don’t believe. I rendered it out as H.264 and the file size is only 1.4MB. Even in the video I can see that the frame rate is at 29.97fps… really have no clue what the issue is
  • Adam Kois
    April 23, 2012 at 10:34 pm
    No neither of those are the issue. I’m not using any footage, all created within after effects. Also open GL is off.
    I just tried something weird though and it worked. I created a new composition and put my old comp into it… basically pre-comped my entire project. Rendered it out and playback is perfect.
    Seems like a glitch or maybe some file got corrupted somewhere?
  • Antonio Mars
    January 12, 2016 at 3:01 am
    Hello. I have After effect CS4 and when I use green screen mp4 footages from youtube, render results are choppy. (background uncompressed video plays fine but mp4 above it runs badly) Can I encode or convert those footages to get a better result?
  • Antonio Mars
    January 13, 2016 at 7:55 am
    I downloaded VirtualDub and mpeg plugin and my mp4 file with size 1.5 mb becomes a 1 gb AVI file. And now it works fine. But what software should I use to transcode it to quicktime file, and will I get a little smaller file size?
    AVI works fine but 1 gb is a little too much for a 8 second clip..
