Activity Forums Adobe After Effects After Effects Rendering Glitch?
  • After Effects Rendering Glitch?
    Posted by Remington Markham on April 5, 2010 at 11:02 pm
    Hi I posted a similar question a few days ago and tried everyones suggestions and had no luck. I decided to upload a video to help people identify this glitch.
    https://www.youtube.com/watch?v=ynuIkDx950w
    Happens in the second half when his arm starts jittering, its jumping to random frames?
    Any clues as to why it is happening or how I can fix it? It’s random and all still frames are fine, the video footage play’s fine before I render it.
    I’m using CS4 on Windows 7.
    Andrew Brown replied 13 years, 4 months ago 4 Members · 3 Replies
  • Brij Nandan
    April 6, 2010 at 7:54 am
    Hello sir,
    I am a student of multimedia in India.
    I probably use raw footage(avi-mpeg2) in after effects cs3 and i have also faced this glitching problem. But i have not any problem with quicktime movies.
    so i want to know which formats are good to import in after effects?
    Well, i used to render my output in avi(xvid mpeg4) format and i found that this is highly compressed and good quality format.
    Is this compression good for output for general purpose?
  • Walter Soyka
    April 6, 2010 at 7:51 pm
    To expand on Dave’s response, not only do you want to avoid using AE for final compression, you should also avoid using compressed media (such as your Xvid AVIs) for subsequent compressions (like MPEG2 for DVD, H264 for web, etc.).
    It’s really best to start with a lossless render and handle all your subsequent compression jobs from that original.
    Walter Soyka
  • Andrew Brown
    May 25, 2013 at 7:53 pm
    Replying to an ancient post in case somebody else finds this useful;
    I was haunted by the same problem, in ever-increasing degrees, for a long time. Render glitches persisted, irregardless of the source material for the projects; different video footage, generated purely in AE, etc. People more knowledgeable than me suggested the following, which I did:
    Render to a hard drive, not an external drive
    Make sure there is ample space on that hard drive
    Set AE to clear the cache every set number of frames during renders
    Check your OpenGL settings
    Etc., etc.
    Nothing worked. The thing that finally solved the problem was switching from rendering .MOV files in animation codec, to rendering .MOV files in PNG codec. Hundreds of renders later, and glitch-free.
