Activity Forums Adobe After Effects After Effects Rendering DVD too slow…
  • After Effects Rendering DVD too slow…
    Posted by Richard Lord on January 1, 2011 at 9:21 pm
    Hi, I am working on a macpro and I am finding that rendering out a DVD from After Effects CS5 is taking a lot longer than expected. Can anyone give me some advice on how to speed this process up:
    First here’s my system specs:
    MacPro (OSX 10.6.5)
    Processor: 2 x 2.93 GHz 6-Core Intel Xeon
    Memory: 24 GB 1333 MHz DDR3
    Disk: 8TB Raid5 / 1TB system drive
    Graphics: Radeon HD 5870 1GB
    Here’s the composition specs I was rendering out – I guess I want to know if these render times are normal or are too slow when considering the system specs.
    Source footage: 720p Quicktime reference movie out of final cut pro 7
    AE composition Colour space: 32bpc
    Composition frame Size: 720×576 widescreen (scaled 720p)
    Duration: 50mins
    Render Codec: DVD – MPEG2, variable bitrate
    Rendering to different drive than source footage.
    Multiprocessing is turned on
    Resulting render time was 6 hours, 11 mins
    I also rendered shorter timelines of under 15mins, and the render times for those were up around 50mins each. Just seems too long. Could the 32bpc colour space be causing the longer render times?
    I prefer rendering DVDs out of after effects because I think it does a better job than compressor – especially when fades to black are concerned, etc…
    Any thoughts?
    Richard Lord replied 15 years, 8 months ago 2 Members · 4 Replies
  • Tudor “ted” jelescu
    January 2, 2011 at 11:13 am
    Yep- don’t! I mean do not render a file compressed for DVD out of AE- never! Render to a lossless (animation, png..) or intermediate (Apple ProRes) codec and then use something like Adobe Media Encoder or Encore to finish your DVD (render to mpeg2…)
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
  • Richard Lord
    January 3, 2011 at 2:29 am
    But why does it encode so slowly out of AE? – I mean, the option is there to use. AE does a great job of encoding to DVD – it just takes too long. I prefer the results AE gives over compressor or other encoders. I haven’t tried encore – but perhaps will to see if it’s any faster and gives a good result.
    My source files in these cases were already in a lossless format. I was just using AE to encode it for DVD.
    January 3, 2011 at 2:00 pm
    AE is not an encoding program Adobe Media Encoder is meant to do just that- encode, so it will do a much faster and better job than AE.
    Tudor “Ted” Jelescu
  • Richard Lord
    January 5, 2011 at 12:42 am
    Ok, great. Thanks for this guys. I’ll use the Adobe Media Encoder.
