After Effects render to Media 100 16:9
Posted by Al J. marschke on March 16, 2007 at 8:28 pmAnybody have a workflo example for geting After Effects to render out 16:9 files that media 100 will be able to put on a 16:9 time line?
Thanks in advance
Al J. Marschke
BluMars Media
Pittsburgh, PAAl J. marschke replied 19 years, 6 months ago 3 Members · 9 Replies -
Floh Peters
March 16, 2007 at 10:13 pmSet up AEs comp as PAL or NTSC widescreen (720*576 or 720*486). Render out into the Media 100 720 codec as usual. When importing into Media 100, make sure that in the import window you set these clips as widescreen (16/9).
Al J. marschke
March 17, 2007 at 1:46 amThat’s the first thing I tried. I ended up having to render as an Animation from a comp set to DV widescreen. Media 100 codec would not let me do it.
Al J. Marschke
BluMars Media
Pittsburgh, PA -
Floh Peters
March 17, 2007 at 10:09 am[Al J. Marschke] “That’s the first thing I tried. I ended up having to render as an Animation from a comp set to DV widescreen. Media 100 codec would not let me do it.”
Where did the Media 100 codec not let you do this? If your comp is 720*576/486 (widescreen) and you render to the Media 100 720 codec there should be no problems. As I said, only make sure that the “Aspect Ratio” is set to “Use 16:9” when importing the rendered file into Media 100.
Al J. marschke
March 17, 2007 at 11:10 amI could not drop it on the timeline. It was rendered 16:9 in AE with media 100 720 codec but that was not enough. The only thing that would work was Animation. The hardware was set to 16:9 when I imported it.
Al J. Marschke
BluMars Media
Pittsburgh, PA -
Floh Peters
March 17, 2007 at 12:05 pm[Al J. Marschke] “I could not drop it on the timeline. It was rendered 16:9 in AE with media 100 720 codec but that was not enough. The only thing that would work was Animation. The hardware was set to 16:9 when I imported it.”
As I said, when importing make sure that “Aspect Ratio” is set to “Use 16:9” in Media 100s Import dialog box.
Al J. marschke
March 17, 2007 at 12:15 pmAspect ratio is and always has been 16:9 in the media100 hardware…hence the problem.
Al J. Marschke
BluMars Media
Pittsburgh, PA -
Floh Peters
March 17, 2007 at 5:47 pm[Al J. Marschke] “Aspect ratio is and always has been 16:9 in the media100 hardware…hence the problem.”
It is okay to have this set up to 16:9 in the hardware settings, but you also need to select 16:9 in the Import window (CMD-I) when importing your rendered clips. AE does not write an aspect ratio flag into the rendered files, therefore they get imported as 4:3 into Media 100 i (btw, in Media 100 HD you can change from 4:3 to 16:9 and back easily).
Andrew Mehta
March 18, 2007 at 2:01 amMedia100i 7.5
File>>Import>>[Scale Image Box] *Fit to Video, or *Retain size – one of those should make the difference. Either fitting it to 16:9 if that’s what your hardware settings are, or else retaining 16:9 if that’s what it was exported as.
Try both, get lucky.As Floh has been saying, it’s all about the settings in the import window when you import the clip into M100.
