Activity Forums Adobe After Effects After Effects Render Displays Wrong Clips
  • After Effects Render Displays Wrong Clips
    Posted by Zachary Silver on November 24, 2011 at 1:00 am
    In my project, I had some clips which I replaced by using the “set proxy” option. I’ve rendered it out previously, and it’s worked out perfectly. After making a few changes and setting a few more proxies, now, when I render it, it displays the original files instead of the proxies I set. When previewing in AE, it looks perfectly fine, but after rendering it displays the original files. If anyone could help it would really be much appreciated.
    Zach
    Zachary Silver replied 14 years, 10 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    November 24, 2011 at 3:26 am
    The Render Settings dialog window has a setting that controls the use of Proxies during a File Render. This setting defaults to Use No Proxies – IOW, the original (pre-proxy) files will be used.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Walter Soyka
    November 24, 2011 at 3:28 am
    If you are rendering with Best Settings, AE will ignore proxies and render from scratch.
    You must set Proxy Use to “Use All Proxies” (or “Use Comp Proxies” for comps only, not footage item proxies) in your item’s render settings in the render queue if you want to use your proxies for final renders.
    Walter Soyka
  • Walter Soyka
    November 24, 2011 at 3:30 am
    My apologies for essentially duplicating Roland’s post. I missed it in the time it took me to write mine.
    At least you can be pretty sure you’ve gotten good advice!
    Walter Soyka
  • Zachary Silver
    November 25, 2011 at 3:39 am
    Aha! Truly amazed at how quickly I received two responses. Thanks so much to both of you.
