Activity Forums Adobe After Effects After Effects – Render 1080 Progressive
  • After Effects – Render 1080 Progressive
    Posted by Paul Gregory on April 11, 2012 at 4:30 pm
    Hello there,
    Im just wondering how to render out a prores movie 1920×1080 progressively from after effects CS5? its a motion graphic created within the application, I have field render OFF in render settings, but when i import the final render into FCP, it has an upper field dominance??
    I dont get it as nowhere along the way have a ‘created 2 fields’
    Please help!
    regards,
    Paul Gregory
    Pat Hindman replied 13 years, 10 months ago 3 Members · 3 Replies
  • Paul Roper
    April 11, 2012 at 5:12 pm
    It’s a Final Cut thing. For some reason it always wants to interpret ProRes footage as upper field first. Don’t worry – all you have to do is right-click on the word ‘upper’ (under the ‘Field Dominance’ column) in the browser BEFORE you edit it into your timeline and change it to ‘none’. Your footage is NOT fieldy from After Effects.
    If you’ve already placed it into the timeline, FCP is too dumb to make this change automatically follow through to the timeline, so you’ll have to change it in the timeline, by selecting the clips(s) in the timeline, pressing command-9, then right-click-changing it to ‘none’.
    Maybe there’s some kind of ‘default interpretations’ prefs file somewhere (like After Effects has) that you can edit to change this behaviour. If there is, maybe someone can point us to where it lives.
    – Paul
  • Paul Gregory
    April 12, 2012 at 9:59 am
    Many thanks guys. Just the answer i wanted hear!
    regards
  • Pat Hindman
    November 12, 2012 at 8:13 pm
    I’ve also noticed that FCP’s Viewer usually doesn’t immediately update it to showing as progressive either. You have to “force” the Viewer to update by turning the clip off or on (Control B), or briefly scaling it up and back down (don’t use Cmd Z/undo to put it back…you have to manually put the scale back to where it was), OR, bring the opacity down a bit then back up (again, don’t use “Undo” to put it back as it will go back to “fieldy”). The quickest method I’ve found is the opacity change on the timeline itself as long as you have “Show Keyframe Overlays” selected in your sequence settings. “Tis a pain indeed!
