Activity Forums Adobe After Effects After Effects quits on intensive render CS3
  • After Effects quits on intensive render CS3
    Posted by Travis Peterson on March 5, 2008 at 7:39 pm
    Hey guys
    I’m trying to render a 4 minute HD (dvcprohd 1920×1080) piece with over 300 3d layers and complex lighting. My machine hasn’t made it through a render yet– it gets about an hour in and then just freezes the whole machine up. My next step is to just render all the pre-comps and bake the plugins in and then do a master render but that sucks. I just bought a Mac Pro quad with 6 gigs of ram and I would love to just be able to render the whole thing out. Any tips on HUGE renders and how to make them work?
    By the way, I am using AE cS3 on Leopard. Both are updated to the lastest. And yes, I fixed the quicktime itunes 10 minute render debacle.
    Steve Roberts replied 18 years, 6 months ago 2 Members · 1 Reply
  • Steve Roberts
    March 5, 2008 at 8:59 pm
    Render to a still sequence. When the box quits after doing frame 351, start up the render again at frame 352. When done, import the sequence back into AE for a quick conversion to another format if you want.
    Go to the Secret prefs and purge RAM every 5-15 frames or so. When accessing the prefs>general, hold down the shift key until you see the big Prefs Drop-down menu. Then look for Secret at the bottom. Monitor your RAM usage as it renders.
