Activity › Forums › Adobe After Effects › After Effects Quartz Compositions
Posted by John Mark on October 19, 2013 at 2:02 amIs there a render setting where I can render in “Quartz” as a graphic composition or a plugin used for Play-out from BB-TV
Have a look at this ptf – https://www.ninsight.com/fichiers/docs/bbtv/BBTV_Documentation_En.pdf
(scroll down to the bottom “graphic overlaying”
– Thank you CC
A News Graphic Lover
Angelo Lorenzo replied 12 years, 11 months ago 3 Members · 6 Replies -
Tero Ahlfors
October 19, 2013 at 5:35 amI’ve never heard of that. I’d wager the Quartz Composer is the only program that’ll do that.
Angelo Lorenzo
October 19, 2013 at 8:03 pmQuartz Composer is, in a very broad sense, an embedded Apple technology similar to Adobe Flash in that it allows you to attach programming to visual elements.
While I’ve seen Quartz compositions converted into After Effects plugins (Noise Industries FxFactory Pro comes to mind), I’ve not seen any tool to convert AE to Quartz.
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
John Mark
October 20, 2013 at 12:40 am[Angelo Lorenzo] “FxFactory Pro”
So this application is able to render out in “Quatrz” format embedded into after effects?
Thank you.
Angelo Lorenzo
October 20, 2013 at 1:07 amIt’s able to apply Quartz comps as After Effects filters, basically allowing you to create your own filters/effects. These would then be rendered out in After Effects as normal video, just like any other filter/effect.
John Mark
October 20, 2013 at 8:54 amDo you know what the effect may be called. There seems to be quit a few
Angelo Lorenzo
October 20, 2013 at 7:03 pmNot quite sure I understand your question. Quartz comps used as plugins need to be created in an optimized way for that usage and then adapted with a 3rd party program. None of the After Effects native plugins use Quartz (to my knowledge); I believe the general programming language for them is C++.
